Results 1 to 2 of 2
Thread: 2017 Gen2 Coyote - pull timing on time after launch
    Jan 2024
    3
    Does anyone know a way to pull timing based on time? I know this is available for time and speed on standalone. I am also running an AMS2000 for boost control.
    Based on the track's condition, I would like to pull boost(AMS does this); I also want the ability to pull timing at 1.2 seconds for 1 second, but I'm not sure how this would work on the stock ECU.
    Any Thoughts?
    Jun 2020
    980
    You could use transient tip-in retard with delay events and hold events used to get the times right. What I don't know is if you set delay to the max of 255 events, is that 255 revolutions, cycles, or total fire events. If it's revolutions that could get you up to 2.5 seconds of delay depending on average engine speed. If its fire events, it would only get you about .6 seconds of delay before the timing retard kicks in.
