Results 1 to 17 of 17
Thread: At my wits end
    Nov 2022
    42
    At my wits end
    Ok so I have ls swapped a wagon and have tried 2 harnesses and new plugs anyway I get spark all the time. Injectors only fire twice with noid light then light gets faint and dies. If I spray intake it fires and runs which tells me a fuel issue. Tried 2 crank sensors and 2 cam sensors no codes vats is deleted I triple checked.. im at my wits end I removed the injectors and cleaned and manually checked with power probe they are working have 58 psi at the rails they will squirt twice then don't anymore so car won't start any pointers please
    Nov 2022
    42
    Oh and the engine is dbw. Has the ams merica cam shaft is a 2005 the tac module seems to be working making the throttle pedal move when I use gas pedal just am not getting injectors to consistently fire
    14,066
    Post the tune file and log if you can.
    Nov 2022
    42
    Okay i will later on on it
    Nov 2022
    42
    I had to leave and go somewhere it has me mad
    Nov 2022
    42
    How do I do that I've honestly never done it
    Nov 2022
    42
    Here are the files
    Oct 2004
    675
    Unless you are trying to crank the car on the moon, you are not getting a real MAP signal.
    Mar 2014
    McAllen,TX
    161
    Quote Originally Posted by gametech View Post
    x2 your map is reading way off and maf aint working correctly, check wiring or swap out map
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Nov 2022
    42
    Im sorry im real new on all this what should map sensor reading be
    Nov 2022
    42
    It's got a new map sensor and harness isn't twice could it be a messed up map
    Nov 2022
    42
    Quote Originally Posted by kstwrt91 View Post
    It's got a new map sensor and harness is new twice could it be a messed up map
    Oct 2004
    675
    Around 100kpa, depending on altitude. That would be about 14.7psi. You can change your scanner to show whatever units you prefer. And the sensor reading should fluctuate a bit while cranking. Your MAP and MAF readings never fluctuated at all in your cranking log. For anyone to help on the electrical side, you will have to give an exact part number for your map sensor, as well as what your harness is supposed to be for and what type of harness it is (stock pullout, aftermarket swap, etc.).
    Nov 2022
    42
    So my buddy informed me it's an Amazon special map sensor the reason maf isn't reading is because I don't have it in the intake piping right now... I was spraying it with nose candy just to verify was getting spark... would the map sensor screw with the injectors not firing all entire time?
    Nov 2022
    42
    And it's a hpi swap harness
    Oct 2004
    675
    Pretty much all of the china swap harnesses are pinned wrong in one way or another, so who knows what problems may lurk there. However, those problems can be fixed when they arise. The MAP sensor is a different story. In order to have the correct linear and offset, as well as just a decent chance of getting one that works, you need to get a real GM sensor with the correct part number for your engine. This may or may not fix the no start issue, but it will be necessary either way. Just so you know, one of the common pinout problems on swap harnesses is backward MAP sensor wiring, so you should check that first. Also, as an example, the pinout is different between an ls1 and ls2 MAP sensor, and I have no idea which other MAPs may be pinned differently.
    Nov 2022
    42
    It was the map sensor thank you
