Results 1 to 10 of 10
Thread: 2011 Yukon Denali 6.2 Tune
    Nov 2024
    Newport, PA
    7
    Lightbulb 2011 Yukon Denali 6.2 Tune
    Working on a tune for my own '11 GMC Yukon 6.2; I have attached the file for any pointers or basic recommendations after review. Vehicle is stock other than CAI/Cat Back Exhaust/Cats Gutted due to prior problem.
    Thanks!
    14,067
    Logs will help too, so that we can see how it runs with the changes you made.
    Nov 2024
    Newport, PA
    7
    I just did a couple revisions tonight and have not logged it again yet with the changes. I will load it up tomorrow.
    Anything you prefer to be added to the log?
    Nov 2018
    Middle TN
    97
    It's got a lot of timing in it for a truck, hopefully you run good gas. Your low octane table though.... If it ever finds it's way there it's going to fall on it's face under acceleration... "Usually" you copy your high octable and paste in to the low, then subtract like 8 degrees from it. Some people do more, some do less. When you log it make sure knock retard is in there.
    I have a 2010 yukon Denali so I'm not speaking from theory. Whatever that's worth, or not... lol
    Mar 2022
    Olathe Ks
    137
    DOD - disable
    Look at your transmission for sure.. TC slip especially and NO Lockup in 1-3 gears for sure.
    I have a 2014 with some mods. but this is the minimum for a stockish yukon/truck.
    Nov 2018
    Middle TN
    97
    Quote Originally Posted by Tfoggy View Post
    DOD - disable
    Yes absolutely this.
    DOD - disable
    Can you elaborate a bit more on the transmission settings? I'm interested in doing this.
    Nov 2024
    Newport, PA
    7
    So, on my previous log with this timing map, there was no knock retard...log was done with normal driving, highway and a couple good pulls. I do run 93 octane gas.
    I also just tweaked my low octane table...thanks for that.
    As for the transmission settings, do you have a screen shot you can share?
    Interested in the transmission settings as well if you ever got them.
    Oct 2023
    27
    I think it's as simple as disabling lockup in gears 1-3 by setting the engage speed to max.
    I also disabled the torque management and removed the 2000rpm limiter when the brake is pressed which makes a big difference in launching.
