2 Questions. What is causing this saw tooth pattern in my rpms while cruising? You can feel it what ever it is and its driving me nuts.
Also is the map supposed to read this high?
WONGTUNE.hpt
WONG.hpl
WONGTUNE.hpt
WONG.hpl
Your ignition timing is going crazy as well. At first i thought it might be a misfire.
Ignition swing at idle is due to a cam swap of some size. its a little choppy.
Ignition swing at idle is your adaptive idle control at work.
Are there any more TCC pids available? It looks like the converter unlocking and locking again.
email=[email protected]
