Results 1 to 3 of 3
Thread: 04.5 5.9 Cummins VGT Tune
    I recently put a DPS VGT in my 04.5 5.9 Cummins. Im currently using my orig tune that I built and had some help building from this forum. It runs great, but want to tinker a bit to get some egt's down and make this VGT even better. Has anyone done a VGT in a 5.9 and built a tune? TIA.
    2004.5 Cummins.
    DPS VGT- S363/68/Ball Bearing T3 Turbo
    2nd Gen Swapped
    50HP BMS/Exergy Injectors
    DPS T3 2nd Gen manifold,
    CAI
    5" turbo back exhaust,
    BD lift pump with 2 mic filter and h2o separator,
    banks intercooler, Banks intake horn,
    slightly built tranny.......
    Sep 2023
    438
    How are you controlling the vanes?
    Vanes are controlled by the DPS controller box as well as a little dial. The way I understand it works is it monitors the exhaust pressure, boost pressure, TPS, and adjusts as needed. It has a little dial controller so the user can select how early they want them to open and what the desired starting point is. There is a toggle to turn on exhaust brake which is activated by TPS monitoring. There is no tuning capability through the DPS controller box.
    Currently everything works well with the tune I have loaded which was built for a larger turbo as you may recall I had some smoke and spooling issues where I live at 10k ft. This new unit is night and day difference. On my only test drive so far, I saw 35psi at around 2900rpm at 10k ft, but EGT's were through the roof at 1400. I need to work on that. It gets to 10-15 PSI super quick from a stop and would probably roast the tires if I chose to. There is zero smoke! I am waiting for a couple other parts for the truck and I will then get back out and do some logging. I think I need to pull some timing and fuel back from this tune to make it a more reliable tow vehicle. Was just looking to see if anyone had a similar setup to get a base tune from.
    2004.5 Cummins.
    2nd Gen Swapped
    CAI
