Page 7 of 7 FirstFirst ... 34567
Results 121 to 128 of 128
Thread: How is delivered torque calculated in a gen3?
  1. #121
    Oct 2014
    Seattle
    145
    It's level multiplied by gain. So where you're seeing I have 9.0 the other tune is effectively 9.5. You can go up as much as you like, but keep in mind this looks like real knock.
    KR happening with sustained load is why I asked about plugs and suggested lowering PE threshold. Where are you at on this?
    I haven't had the opportunity to get out and try the 70KPA change. The last change to the spark table yielded no retard but I want to confirm with another drive. Timing at 4000rpm down to around 14.25 for a low point. Pretty conservative...
  2. #122
    Banned
    Mar 2022
    Indiana
    4,289
    It shouldn't need to go that low. Is there oil in the intake? Look into it with a flashlight.
  3. #123
    Oct 2014
    Seattle
    145
    I have fought with oil in the intake. I have done the "tricks" you tube has described as being fixes-and they were improvements. 6 weeks ago I installed an Elite Engineering catch can. I am using a comp cams full shaft rocker set up and I wonder if it oils more liberally than the stock set ups and is creating my problem. Also considering reducing the orifice in the valve cover with a restricter, by like say 25%. It's a pretty big hole-no pcv valve here. And yes the catch can is catching some but not excessive.
  4. #124
    Oct 2004
    699
    I just saw that you have AFR 205 heads. Does the porting on those break through between the headbolt holes and the intake runners? I know when you port factory heads you have to use sealer on some of the head bolts to avoid sucking valvetrain oil into the intake ports.
  5. #125
    Oct 2014
    Seattle
    145
    Quote Originally Posted by gametech View Post
    No they don't on these heads. The oil I'm dealing with coats the intake runners and runs freely down into the head intakes. I've gained on this problem and thought I had it solved, but perhaps not...
    Another avenue I'm looking into is the oil I use-currently Driven GP-1 10-30wt. Next oil change I'm gonna switch to Driven LS30 5-30wt It's advertised to reduce consumption through the pcv valve by limiting vaporization and foaming... and is specifically for LS engines.
    IDK, Seems I always learn the hard way lol.
  6. #126
    Oct 2004
    699
    Learning the hard way makes the lessons stick, but it sure sucks getting to that point. I ordered a bunch of stuff when I planned to mod my GTO, but did not use the parts for a while. By the time I was ready, the ARP studs that were for pre 2004 blocks (oops) could not be returned. The Comp shaft mount rockers had something drip on the box and corrode 2 of the rockers. The wrong fuel level sending unit that came with my fuel cell could not be returned. A few other things went sideways, but you get the idea.
  7. #127
    Banned
    Mar 2022
    Indiana
    4,289
    Quote Originally Posted by GBull View Post
    Best trick I know of is converting to LS6 style out the valley cover. Probably pay for itself vs that $65/6qt boutique oil.
  8. #128
    Oct 2014
    Seattle
    145
    I'll look into that..
