Results 1 to 15 of 15
Thread: 98 Camero with long tubes - will a tune fix this?
    Sep 2024
    27
    Hey guys I need some help, not my car but my cousins car. Car idles fine, but when it comes up to temp, starts bogging and backfiring. LTFT are adding a ton of fuel across the board. Ive been playing with hptuners on my LS swap and know enough about LS engines and tuning to be dangerous, but not enough to diagnose someone else's build. I think I've ruled out anything mechanical, o2 sensors are new and there are no leaks on the intake or exhaust (as far as i can tell), car is only throwing a code for the EGR valve. All sensors appear to be reading and to the best of my knowledge are functioning properly. Im not a pro and dont want to take on tuning someone else's vehicle so the final question is: will a tune fix these issues or is there something else going on here? I dont want him to pay for a tune and have that not solve the problem. Apparently the car drove fine before the headers, but I never saw it. Also, to my knowledge, the tune file should be stock, but it is a used 98 camero.. . . . .seems to me that it should be throwing some other codes if it were truly stock. If a tune will fix it, any recommendations for a mail order tune?
    Vehicle:
    98 Camero 5.7 Manual Transmission
    Mods:
    Cold air intake
    340 lpm fuel pump
    long tube headers
    high flow cats
    egr delete
    Tune File and logs:
    Camero.hptCamero.hplCamero run 2.hpl
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    Double check the exhaust is sealed up then it looks like a tune can fix it.
    Did the MAFs get moved with the CAI? Do you have the tools to check fuel psi. while you are driving it?
    I would put it in SD and tune the VE table first based on fuel trims then go back to tune the MAF if you want to keep it.
    Sep 2024
    27
    Mass airflow sensor appears to be in the stock location. I can take a closer look at the exhaust manifolds on the heads, but looking underneath the welds are good and I can?t see any leaks there.
    Banned
    Dec 2024
    214
    IAT 54c, 129F... If it's cold where you are, that can make it lean, by a lot.
    Sep 2024
    27
    We?ve had some cooler days here in phoenix, but not relative to the rest of the world.
    Arizona
    1,291
    Quote Originally Posted by snwboarder48 View Post
    Weve had some cooler days here in phoenix,.
    not sure where youre at in phx, but in this phx its pretty cold....
    Banned
    Dec 2024
    214
    "cold air intake", 129F intake, I don't think any sane person would call over 100F a cooler day.
    Sounds like you need to fix/replace a sensor/wire.
    Sep 2024
    27
    This car is not in pristine condition, it?s been well loved haha. I?ll take a closer look at that.
    Feb 2024
    357
    If it is not blocked off from the engine bay it is a "Hot air intake" and it would have been more beneficial to keep the factory intake ducting, where the air is drawn in from outside the engine bay
    Banned
    Mar 2022
    Indiana
    4,289
    IAT isn't going to throw off fueling. What do you think the IAT sensor is for?
    It's adding 40% fuel. If stock engine then restore stock O2 settings. Increase CL enable temp for longtubes so O2's are warmed up. (attached)
    This problem has more to do with a 340lph pump behind a reg that'll only support 255. Pump probably got damaged. Check fuel pressure.
    North Carolina
    4,857
    I'd verify fuel pressure as well.
    Also, MAF seems to be reading a touch lower than it should especially at idle. I'd clean the MAF. That can move fuel trims by 15-20%. Check again for any airleaks behind the MAF. The rubber elbows on the PCV for those often rot out.
    Headers alone shouldn't have changed all this that much. The popping you describe is not going to be a tune issue but likely a cracked spark plug or burnt wire. both of which happen often with new header installs.
    Sep 2024
    27
    Quote Originally Posted by twenglish1 View Post
    I agree, unfortunately car has been around the block a few times and came this way. Have to live with it for now.
    Sep 2024
    27
    Can definitely take a look at that. Pump was ?upgraded? when the factory one went out. Will try to verify fuel pressure.
    Sep 2024
    27
    This has been my thought as well, headers on a relatively stock motor shouldn?t require a tune right? I?ll check that out as well. Appreciate all the insight guys, really do. I?ll report back with findings, busy week at work, so not sure when I?ll be able to get back out there and help him out, but I will keep you posted!!!
    Sep 2024
    27
    Just wanted to report a k, good tip on checking out the fuel pump! Not enough capacity in the stock regulator and fuel was boiling in the pump causing a drop in pressure! Replaced with stock unit and works great.
