Results 1 to 3 of 3
Thread: 2023 Challeger HP70 Channels?
    What channels do I need to add to my configuration file for a trans info? I bracket race and want to see if my car shifts at the same RPM and if the application of the shift is harder or softer? Searching for a reason my car isn't consistent between passes. Starting with the transmission data first.
    Aug 2021
    Indianapolis Area
    453
    Tranny not being consistent could be a couple of different reasons...
    Start looking for:
    - RPMs (engine, input shaft, outshaft)
    - Torque
    - Gear
    - Throttle control
    - Torque converter
    - ... (add channels related to tranny on VCM Scanner channels)
    Analyze the chart. Depending on the issue, it will be necessary to add/remove some PIDs
    If you need tune support, send me an email.
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Quote Originally Posted by DodgeBoy_8HP View Post
    Start looking for:
    - Torque
    - Gear
    - Throttle control
    - Torque converter
    Thanks. I added the channels now need to get to a test n tune.
