Page 5 of 5 FirstFirst 12345
Results 81 to 89 of 89
Thread: Acronym List
  1. #81
    2,810
    Most of these probably need to be asked in the particular section for the vehicle/platform in question. Things have changed a lot since this thread was started.
  2. #82
  3. #83
    Jun 2024
    Europe
    33
    Hoy together
    Great list!!
    Would it be possible to add:
    TCC - Torque Converter Clutch
    OSS - Output Shaft Speed
    Best wishes
    10le
  4. #84
    May 2024
    23
    Quote Originally Posted by sook View Post
    I've been trying figure this out for a couple of days.
    Hey Sook, were you able to figure this out. In Burble settings I'm trying to figure out what Bypass DCMS means.
    Kevin
  5. #85
    Feb 2008
    TX
    16
    I may get flamed, but oh well. What do the colors mean when you look at the compare files and do changes?
  6. #86
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    It's fairly intuitive when you work with it some. I do remember stumbling across someone explaining it in a vid but I don't remember where. I think if you go down the rabbit hole and search things like "how to use HPT VCM soft ware" you will fine more info. than you want.
    Here are the basics:
    Blue with a center white stripe, no change.
    Green, different from the original file.
    Green, white stripe, pink at bottom, you just changed it in that file and it is now different than the original.
    There are a lot of short cuts that are learned (I don't know where) similar to key board hot keys or key stroke short cuts. This is also a perishable skill, as nice as it is to learn the short cuts, if you don't use them frequently, you loose them.
  7. #87
    Feb 2008
    TX
    16
    ^ Thanks^ "perishable skill", gonna have to include that in my vocabulary. Seems pertinent.
  8. #88
    28,778
    Quote Originally Posted by Chevy-Art View Post
    https://www.hptuners.com/help/VCM-Ed...lor_coding.htm
  9. #89
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    278
    How about AD counts, didn't see anything on it
