Results 1 to 14 of 14
Thread: L5p tune revision needed or new tunes
    Nov 2022
    Miami
    My 2017 silverado l5p is running weird my vpos goes from 45% at 75mph to 15%. And everytime I hit the gas my truck surges and it kind of cuts off power
    Banned
    Jan 2020
    Arlington WA
    247
    Are you running sotf tunes?
    Feb 2023
    Similar issues, the truck runs fine after writing the tunes. Shut the truck off, the next time I start it up it runs strange. High idle never kicks in, but if you bump the throttle at all it jumps to 1200 RPM and just stays there and never drops until you shift out of park. When you shift back in to park same thing (This happen if the engine is cold or at temp on a hot day). Exhaust break doesn't work and when you drive its very jumpy with the power dropping off/surging to life. It can barley make it up inclines and the turbo spool doesn't sound right. If I write the tunes again all these issues disappear on the first drive, but when I turn the truck off and start it again all the trouble is back. Thoughts/Advice???
    19' L5P, full delete, down pipe, 5" exhaust, Stealth 67v2 turbo, Wehrli intake and piping, Motor-Ops SOTF ECM and TCM tuning
    Banned
    Jan 2020
    Arlington WA
    247
    If you want to send me the tune i can take a look at it.
    Jun 2023
    13
    Have similar issues . I found it helps mine when trans temp reaches 142+ then I turn off the truck and turn it back on.. then it’s fine till it cools down again. No boost with throttle because vanes wide open, at idle they close making boost before it’s restarted . Gdp said they “sent log and tune to their engineeers”
    2019 Silverado 2500 High Country Duramax
    2008 6.4 Powerstroke
    Jan 2025
    2020 l5p
    Quote Originally Posted by Powerstrokecustoms View Post
    my 2020 chevy l5p Duramax was just tuned and deleted. now even when the engine is up to temperature it will start high idling. the only way to make it stop is to shift it in gear. it is driving me insane is it the tunes? can i make it stop with different tunes? please help
    Jan 2025
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    490
    Quote Originally Posted by duramax20 View Post
    there is an issue in the backend of the file. you will need UDP and XDF to fix it more than likely
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Jan 2025
    3
    I also have the exact same issue with my recently deleted 2020. Has anyone proven anything that it?s tune related? The shop that I got it done at is fighting me that it has anything to do with the tune but it never acted like this before getting deleted.
    Jan 2025
    3
    Were you ever able to find a solution?
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    489
    Quote Originally Posted by Bred10 View Post
    How recent is "recently"?
    If an engine starts to act up within 5 or so drive cycles, it's possibly the tune.
    But if it's been weeks or months, sorry, there is something wrong with your vehicle.
    Jan 2025
    3
    Quote Originally Posted by omega_5 View Post
    Recently deleted being like 10 days ago and the problem with the idle was from the first start up after being deleted which has never gone away. The shop that did the delete changed out my thermostats which nothing and also changed both my 4 month old batteries to brand new ones which also did nothing. That’s what is leading my to a tuning issue but they figure different.
    Aug 2005
    Maidstone, SK
    489
    If it did it right from when the tune was loaded, it's a tune issue.
    I'm going to speculate it's yet another case of loading an operating system or calibration that wasn't meant for that truck.
    Jun 2024
    I may or may not be experiencing a similar issue. My 17 Chevy 2500 has recently started to stutter or stumble when I give it throttle. It was fine for almost a year after tuning but had a service on the truck and now I have the stutter issue but no one seems to know why. I have a trans tune as well. Buying a new TCM tomorrow and having it programmed stock to see if that helps but I do not have much faith that it will work.
    Any ideas?
    I am not very technical so any help is appreciated.
    The service was oil, fuel filter and thermostat replacement. I have changed the fuel filter 4 times to confirm it was not that. 1 shop did 2 I did 1 and another guy did the 4th.
