Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Successful Gen 3 Coyote Ghost Cam tune request
    Anyone has for the 2016 ? With the 18 manifold
    Apr 2022
    Ghost cam
    I put that tune in and when the ac is on it hunts for idle and won?t ever steady out and chop any help to point me in the right direction would really help
    Quote Originally Posted by Treyton_Walker View Post
    I suspect with the AC on it's exceeding the load for the mapped point at idle for the chop.
    Jan 2025
    will this work with my automatic?
    Sep 2024
    3
    Correct me if I'm wrong, but guys this only effects idle from a throttle percentage. so Your range above idle shouldn't be effected by the ghost cam file......Am I correct in that statement?
    would love to know what is changed but I understand everyone needs to make some cash.
  6. #26
    Oct 2016
    Poland
    2,037
    Quote Originally Posted by Mad67 View Post
    If properly tuned - yes
  7. #27
    It's a very crude solution. More of a "shits and grins" type of thing. It just affects idle. I'm sure there are better, smoother ways to ramp it in and out, but again...this was just a crude solution.
    It also triggers misfire codes. Because, duh, it's misfiring!
  8. #28
    Feb 2017
    This got me to the promised land. One of the guys on here made this.
    https://youtu.be/xqWFb1pcHwk
  9. #29
    May 2025
    Has anyone done a ghost cam on a 2023 GT? I've tried to create a tune based on the info in this thread, but still can't get my car to idle right.
  10. #30
    Sep 2022
    Clearwater FL
    437
    Quote Originally Posted by Brandon @ PSW View Post
    This works for the most part. He uses -20,0 cam angles and that's very mild overlap. If you command something more aggressive to get the car to lope harder, then tuning it becomes a bit more difficult than this video.
