Results 1 to 5 of 5
Thread: Will I lose access to other tables?
    Aug 2021
    1,142
    When having Support to add tables to your tune, do they assign you with a personalized version of Beta for your tune or will updating to the new version prevent me from accessing other tables?
    I recently had Support add some tables to my tune and it requires a Beta update. I'm afraid I'll lose access to other tables if I update to Beta version 5.1. I am currently running 5.1.310. Will I lose access to other tables or is the Beta version I was told to download only for the added table?
    Banned
    Jan 2022
    fountain valley
    2,379
    when they add a table, they add a table
    it "should" be on all the beta's to come
    that being said, have you ever seen a switch get flipped or the likes (macros go wacky) after updating?
    what parameter did you define?
    May 2014
    USA
    630
    No, they are not personalized in any way, just get the latest beta from the website and it should be there
    Sep 2021
    Kentucky
    1,854
    What was added?
    Aug 2021
    1,142
    Shoot man, sorry. Just seen your post. I wanted to add Reverse Lockout. I could have sworn I had those tables available before and somehow lost them. Support said they have them added but I need to download the Beta version they recommended. I went in to download and it was throwing up a bunch of jibberish, so i just said heck with it.
    Tables:
    [ECM] 490 - Reverse Inhibit Solenoid: Defines the type of reverse inhibit solenoid fitted.
    [ECM] 5340 - Reverse Lockout Enable VSS: Reverse Lockout will enable if vehicle speed is above this.
    [ECM] 5341 - Reverse Lockout Disable VSS: If active, vehicle speed must drop below this to disable reverse lockout.
