Results 1 to 5 of 5
Thread: 2018 GMC Acadia Denali 3.6 with 6T70 transmission - SHIFT FLARE
    Sep 2014
    9
    I own a 2018 GMC Acadia Denali (AWD with tow package) and I occasionally get some slip, shifting from 2 to 3. I believe it?s called flare. It?s like a delayed shift where the RPMs jump a bit.
    Curiously if I accelerate moderately to aggressively it doesn?t seem to flare. Only when driving gently around town.
    I?m thinking of buying HP Tuners. I?m comfortable with cars and computers, I just haven?t tuned a transmission before.
    I?m reading of other 6T70 & Acadia owners having success fixing this.
    Is this TCC related?
    What parameters would I be changing?
    Thanks!
    Brian
    Sep 2014
    9
    After looking at HPTuners supported vehicle list, it looks like the second generation Acadia (2017-2023) is not supported at all. Not sure why, as I believe the transmission from the first gen didn’t physically change much but perhaps the TCM code changed.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    Did you try to read the PCM & TCM? As the supported vehicle list is not always up to date.
    Russ Kemp
    Mar 2024
    Late to the party, but I can confirm for the 2017.5 3.6L Acadia that you can read/write. IIRC it pulled up as a Colorado controller but it had full functionality and definitions.
    I didn't completely fix the 2-3 flare, but approached it like GM 6L transmissions, shift times, TCC lock/unlock. I did dabble with Bluecat tool and input the data for the 6T70, it helped a bit but not a drastic improvement. That said, it was worth trying and ended up picking up another 1-2 MPG after tuning.
    Apr 2025
    new owner of a 2017 Acadia Denali
    Quote Originally Posted by bxd76 View Post
    Thanks!
    Brian
    Hi, new owner of a 2017 Acadia Denali with slight shudder detected, I have 2 drain and fills with Lubeguard and there is improvment but not gone. What is needed to perform this programming?
