I am swapping out my old 8 speed transmission with a 8 speed from a 1320 392. Is there anything I need to do for the swap? I was told I may need to flash the tcm. If so how would I do that?
2019 challenger rt
92mm hellcat throttlebody
ported 5.7 intake manifold
ported eagle heads
Cammotion custom 222/234 cam
stainless works long tube headers
Vs 78/75 turbo
e-85 tuned
3.70 lsd
i would not do anything to it...
i would bolt it in and buy another 4 credits.
then i would get Don to tune it for you : )
*did you get the convertor too?
might wanna consider buying a 3400 since the trans is going to be removed anyways?
tuned right you can roll into it and it will pull away from a stop like it did stock
stab it and there better be traction available : )
i might be able get you a lil break on one
It came with the stock 1320 convertor. So I don't have to change anything? Just bolt it up and flash a tune
2019 challenger rt
ported eagle heads
Vs 78/75 turbo
e-85 tuned
3.70 lsd
A HP70 is a HP70
Where do you want to shift?
Ok. I've been told I had to flash the tcm. And not sure, depends where it makes power. Right now it's 6600, but I may go higher
2019 challenger rt
ported eagle heads
Vs 78/75 turbo
e-85 tuned
3.70 lsd
Someone with a stock 5.7 would have to recalibrate
You are already shifting yours at 6600
Or trying to : )
Stock 5.7 would run into the limiter long before that
That’s why the PCM has to be tuned simultaneously with the TCM
Ok. It shifts at 6600 2nd threw 5th. But, I figured for the price, I got a 1320 convertor and a lower milage trans
2019 challenger rt
ported eagle heads
Vs 78/75 turbo
e-85 tuned
3.70 lsd
if you just bolt it in it should shift at 6200 to 6400
depending on the mode...
and maybe the mood ha.
whoever said you would have to flash it was prolly referring to the glitch
most 1320's have a 2-3 glitch with the stock tune
its intermittent
some 15-17 scat packs have it too
seems like it comes from trying to have the controller offer such soft minimal throttle shifts
i can usually get rid of it with a trans tune
Ok, thanks for the info
2019 challenger rt
ported eagle heads
Vs 78/75 turbo
e-85 tuned
3.70 lsd
