Page 4 of 4 FirstFirst 1234
Results 61 to 80 of 80
Thread: EGR Enable not visible P59 ECU
  1. #61
    May 2024
    i downloaded the file wrote it to my pcm and i still dont have the option to enable the EGR. I have P01 ecu 2001 camaro 6.0 w BTR stage 2 NSR cam. I took the epa course and passed. Is there anything special i need to do? When i open this file it no change
  2. #62
    They don't let you see it in version 5. You have to use an older version that probably can't open a newer file. You need version 4.8.7 or something which you can't download anymore. So you have to hope someone on here can update your file even if you can't see it. Good luck!
    Quote Originally Posted by blindsquirrel
    Hey bud, click this link, it will not make me even a little upset: https://forum.hptuners.com/profile.p...ignore&u=44277
  3. #63
    Mar 2015
    27
    Would someone be so kind and see if they could enable egr on for me? I'm trying to get my wideband working in torque app. Thanks
  4. #64
    May 2014
    USA
    625
    Quote Originally Posted by GoatCheese View Post
    here ya go
  5. #65
    Mar 2015
    27
    Quote Originally Posted by aaronc7 View Post
    here ya go
    Thank you!
  6. #66
    Jan 2024
    11
    I'm not sure if the base file supports the EGR, can someone verify this setting can be enabled in this tune? (changed OS due to supercharger)
  7. #67
    May 2014
    USA
    625
    Quote Originally Posted by newbaufish View Post
    try this
  8. #68
    Jan 2024
    11
    try this
    Thank you!
  9. #69
    May 2020
    13
    It seems as though I have fallen down this rabbit hole too. Can someone please enable EGR for me.
    Thanks,
    Eric
  10. #70
    May 2020
    13
    Never mind. I installed an older version of VCM on another laptop and made the change.
  11. #71
    Hi,
    It has been a while since this file was enabled and I am just now getting to do some tuning after a long winter. It starts, runs and drives.
    But I do not have any EGR voltage. My AEM wideband works and I have double checked my analog connections to the PCM at Red 41 and Blue 55.
    Attached is the file you enabled along with a short log. Not getting any tank pressure voltage either (no fuel pressure sensor connected yet).
    Nov 10 1998 Camaro with 411 PCM EGR enabled.hpt
    start and run May 2 NO egr volts.hpl
    2002 Camaro SS LS1 D1SC 4L60e Yank 3600 Moser 9 inch 11.3 at 120 on 6 psi MT 255/50R16
    1998 Camaro Z28 LQ4 Huron T4 kit 4L80e Circle D Moser 9 inch...........runs n/a construction continues
  12. #72
    May 2014
    USA
    625
    quoted post was deleted so i guess ill remove this
  13. #73
    Please.................it is Saturday morning........would like to do some tuning............can anyone check the file I posted above.......Thank you.
  14. #74
    May 2014
    USA
    625
    Quote Originally Posted by slarsen47 View Post
    try this
  15. #75
    Thanks aaronc7.......................excellent works perfect............saved the day!
  16. #76
    Oct 2022
    46
    Would someone please enable the egr in this file so i can input a second wideband, thanks.
    Attachment 160047
  17. #77
    Feb 2023
    6
    Could i get someone to turn on EGR for me? I installed one to meet emissions. Would love to get tune dialed in today!
    6.0 Idle VE EGR OFF.hpt
  18. #78
    Aug 2024
    any help greatly appreciated
    hey you guys im having the same issue as the op with the same orginal os i upgraded to the 1 bar speed denisty os and cant reenable my egr could someone reenable able it for me please05 gmc sierra sd enhanched.hpt
  19. #79
    Arizona
    1,256
    Quote Originally Posted by gregstahl7 View Post
    us the search feature and find the 14 page long thread for EGR...
    posting on a fuel injector thread shows youre lack of comprehension
  20. #80
    2,747
    Quote Originally Posted by bk2life View Post
    One of us in confused. This is an egr thread?
