Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
Thread: Cam Tune Assistance
  1. #41
    Aug 2021
    1,122
    Quote Originally Posted by avy View Post
    Should I do another log after checking everything? Is there a concern I can learn from what you see?
    Should I wait to upload the newest tune, until I get your response?
    I thought you tried the tune I posted before and that the recent log was the result from it. If you havent tried it yet, then try it and post the log, just unless you dont want to. Up to you.
  2. #42
    Dec 2024
    32
    Ok I will upload it and log it. I wanted got make sure.
  3. #43
    Dec 2024
    32
    Thanks! Log File from Tune dod, cat, second o2, first cam tune - cringer4-1.1.hpt
  4. #44
    Aug 2021
    1,122
    That looks ok. I'd have to see a much longer log with more data to make any changes. Do you have any particular concerns or drivability issues?
  5. #45
    Dec 2024
    32
    I do not. Just looking for it to be efficient. Do you have a recommendation for startup? I would like for it start up with less RPM
  6. #46
    Aug 2021
    1,122
    Get a log of the start up so we can see what its doing and at what temperature. See if this helps at all.
  7. #47
    Dec 2024
    32
    Ok here it is!
    It just isn't smooth as a few guys I know with my same setup. Maybe its just me
  8. #48
    Aug 2021
    1,122
    Not really sure what exactly you are wanting here. You said you want it to start with less rpm and now say it isn't smooth. Is that the initial start or the idle a few seconds after the start? In the meantime, try this.
    startup adj..hpt
  9. #49
    Dec 2024
    32
    Initial start. I will try this and let you know.
  10. #50
    Aug 2021
    1,122
    ok thanks, sounds good.
  11. #51
    Dec 2024
    32
    I like it now. Thanks for the help!
