Firstly you have two main areas in which to change pertaining to Torque Management (TM)
- Engine
- Transmission
Personally I would turn off all engine TM and since I assume you are cable throttle it will have little effect anyways.
Go to Engine ==> Torque Mngt ==> General
Under this tab you can limit the severity of the Traction Control spark reduction to something a little more sane - personal preference I halve it (or more often turn it off with the button) No ETC, so no need to change anything else. I am still not convinced engine TM on non-ETC has much affect, but worth looking at.
Engine ==> Torque Mngt ==> Abuse
I am not certain on what exactly constitutes abuse to GM, but a series of inputs and calculated load, rpm etc etc can trigger this and use ETC (if fitted) and spark to reduce power. Set rpm here to say >7000 and speed <0.
Now for Transmission
Go to Tranmission ==> Torque Mngt ==> Abuse Mode
Disable this and not only setting to disable, zero the torque reduction table and set rpm to say 7000 and speed to 0. I have disabled this on cars (ETC mind you) and left the tables stock and it left me chasing my tail for some time tryin to figure out why I couldn't even turn the tyres without spark going to zero or retarded. As I understand it, abuse again relies on a host of inputs and more difficult to define on non-ETC and earlier models, but actions such as brake and throttle at the same time will cause 'limp' setting and abuse.
Tranmission ==> Torque Mngt ==> Torque Reduction
This is again a little personal preference and application dependant. If you want A4 longevity, it is imperitive that you leave some TM during the shifts IMO. Generally I halve these values on 'Normal' and 25% or less depending on use for 'Performance' (if fitted with Power/Tow button)
Take RussK (and others advice) and set TCC duty cycle to Max 100 and Min 90 - improves driveability amongst other things
I personally wouldn't zero the desired shift times in performance either and perhaps lower the normal times to to closer to 0.3 secs
General comments, take them for what you will.
- MAF curve looks stock (may not be just looks it)
- VE has some funky anomolies like peaking at 5500 and then dropping off etc
- Too much timing on HO table (if stock cam, if not disregard)
- Very large difference between HO and LO spark IMO
- PE far too rich for NA aim for 12.8 (conservative, EQ ~1.14)
- OLFA table is kinda strange, should be 1 at normal operating temp, leaving it rich at high MAP is personal prefernce again.
- Disable COT or set it to same as desired PE
They were just some observations, so dont take them as being critical, just things I would personally look into.
Cheers
