Originally Posted by
bmpcamry09
Got your PM slowStExplorer and replied. But figured I'd post public here too.
Something else to keep in mind is since your at elevation, your fuel trims are going to be off a little more than someone not at elevation anyways. That's what long term fuel trims are for. Your PCM will throw a CEL if it's not happy with your fuel trims so long as you don't have that disabled. Also, your speed density scalars in VCM editor will change if you raise the MAP ceiling. It's easy to forget to make the same scalar change in VCM Scanner so that your data is accurate when you copy and paste by half a percent.
Although I have taken most of the available Ecoboost and Ford courses, I am NOT a professional full time tuner, so take what I say with a grain of salt. I have written several tunes for several of my personal vehicles and also many on the side. In my experience there is rarely need to tune on Speed Density on Ecoboost unless your making some big time modifcations like bigger turbos, etc., and even then, speed density is pretty accurate. Some changes to some of the tables, IE maximum load in the speed density tab on ecoboost trucks are common though. It's hard to be accurate with speed density as your basically never going to be 100 percent in one set mapped point except for at idle. If you really want to tune them accurately, you can force the tune to run in one mapped point at a time and road test. But it?s very tedious.
Regarding the scalars, on pump gas, the factory scalars work pretty well. The only ones I sometimes have to touch are cylinder pressure limit and a few fuel pressure related ones. I also occasionally change scalars on transmission tuning as I have general templates for each trans I tune on and some Ford OS files use different scaling for OSS tables.
Don't be hard on yourself. There is a ton of good information on this forum, but a ton of bad information also. If your serious about tuning, it'll take some time and money. Take some courses and try to network with some professionals. Buy tunes from several different companies and ask them to leave the files unscrambled if possible (some will do this for you, some won't). Once you build relationships, some guys will let you see their files and tuning styles and teach you a ton of info that you won't learn on here.
The best advice I ever heard from a very well known Ecoboost tuner who uses the SCT platform is to not try to "reinvent the wheel", meaning don't try to fight Ford's factory logic so much. Dozens of engineers who do this day in and day out develop factory tunes and generally do a decent job to keep 95 percent of drivers happy. It's us nerdy 5 percent that like to tweak stuff. Keep it safe but make it yours.
