Thread: Llt pop tune
    Nov 2024
    4
    Llt pop tune
    Hello everyone, new to the forums.
    just wondering how i can make a pop tune for the 3.6l llt, i can make it burble by disabling inj cutoff in torque management, but cant figure out what i need to change in maf calibration as the llt ecm doesnt have dfco
    heres my stock tune
    1ici471 rueben OG.hpt
    Banned
    Mar 2022
    Indiana
    4,289
    Lower spark values in the base tables at 15% load.
    Nov 2024
    4
    what spark tables. can you modify my stock tune file and attach it explaining what to change. as i have no base spark with a load table, only lambda. thankyou
    Nov 2024
    4
    Just in case anyone wants to know I've figured it out by messing with spark and fuel tables,
    You need to change your spark tables, the 4 tables that show on the left.
    The data changed on the table is on the first two columns from the rpm range 2000-6700, I retarded spark to -10?
    It won't pop until your car is heated up, and wouldn't recommend doing this tune. It is mainly for the fun, if you have an exhaust and high flow cats, and if they sit lower than standard it will be ok, but with standard manifolds I wouldn't recommend as you will blow up your cats
