Results 1 to 3 of 3
Thread: ARM64 support
    Jan 2025
    Lille, France
    3
    ARM64 support
    Hey HP Tuners guys,
    I'm not very smart, so I bought an ARM64 computer and decided to make it my new tuning computer.
    Stable VCM Suite is ok, Beta is not even launching, but I'm pretty sure you're working on it :
    Code:
    Description: A .NET application failed.
    Application: VCM Editor.exe
    Path: C:\Program Files\HP Tuners\VCM Suite (Beta)\VCM Editor.exe
    Message: GC heap initialization failed with error 0x8007000E
    Failed to create CoreCLR, HRESULT: 0x8007000E
    dotnet --info
    Code:
    Host:
      Version:      9.0.2
      Architecture: arm64
      Commit:       80aa709f5d
      RID:          win-arm64
    .NET SDKs installed:
      8.0.406 [C:\Program Files\dotnet\sdk]
    .NET runtimes installed:
      Microsoft.AspNetCore.App 8.0.13 [C:\Program Files\dotnet\shared\Microsoft.AspNetCore.App]
      Microsoft.NETCore.App 8.0.13 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App]
      Microsoft.NETCore.App 9.0.2 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App]
      Microsoft.WindowsDesktop.App 8.0.13 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App]
      Microsoft.WindowsDesktop.App 9.0.2 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App]
    Other architectures found:
      x64   [C:\Program Files\dotnet\x64]
        registered at [HKLM\SOFTWARE\dotnet\Setup\InstalledVersions\x64\InstallLocation]
    Environment variables:
      Not set
    global.json file:
      Not found
    Learn more:
      https://aka.ms/dotnet/info
    Download .NET:
      https://aka.ms/dotnet/download
    Please note VCM Editor and Beta work very good in Stable channel.
    Successfully flashed a few CopperHead and a SpanishOak.
    Thank you guys, hugs from France !
    Update : here is the real error log behind the VCM Editor crash
    Code:
    Nom de l'application d?faillante : VCM Editor.exe, version : 5.1.3948.0, horodatage : 0x666b0000
    Nom du module d?faillant : vcmssm-64.dll, version : 0.0.0.0, horodatage : 0x675341e9
    Exception code: 0xc0000005
    Fault offset: 0x000000000183173b
    Identifiant du processus d?faillant*: 0x42AC
    Heure de d?but de l'application d?faillante*: 0x1DB864442E99DBA
    Chemin de l'application d?faillante*: C:\Program Files\HP Tuners\VCM Suite (Beta)\VCM Editor.exe
    Chemin du module d?faillant*: C:\Program Files\HP Tuners\VCM Suite (Beta)\vcmssm-64.dll
    ID du rapport*: 448e1143-72a2-4fb0-b1e1-c70728e77f3b
    Nom complet du package d?faillant*:
    Package d?faillant*– ID d'application relatif*:
    Aug 2020
    13
    I tried to do different emulation settings in the Properties of the application, but it would still fail to open. The Stable release version I had to install the .net framework 8 for ARM64 and it opens without issue.
    Were you able to get drivers installed to recognize the MPVI2+ or 3 with your ARM based PC? Also, what type of PC did you go with?
    Aug 2020
    13
    I was able to use my PC without issue.
    Surface Pro 11 with Qualcomm Elite processor. Didn't even need to change drivers.
