does anyone have config files and charts for v3 software? working on a 12 regal gs
2.24 configs should open in 3.0
You can always use the old scanner if its a must until your familiar with the new setup
99 silverado 1500 5.3, 30 over, all new ported, polished, and milled heads 30 thou, 220 226 custom BEI cam. 2" intake valves, ported & polished TB, Long tube ceramic coated headers, magna flow cats, y pipe, 3" magnaflow, vera ram air intake, I6 TB stall, All new Drivetrain, 3 Trans coolers, Auburn E-Locker, 4.56 gears, Throttle body bypass, Flex-a-Lite E-Fans, LS1 e-fan harness, ASP Under Drive Pullleys, HP Tuner Pro. 1 Bar MAP SD OS upgrade. Amsoil EA Bypass Oil Filtration system.
I can't get any of the Fuel Trims working on my LNF Solstice. Any ideas why? I try to put them in a chart and no numbers show up on STFT and LTFT is constantly -58%.
Edit: I don't have the STFT Bank 1 in channels. It is non existent...so...?
2nd Edit: I found them after I went to Vehicle>Repoll For Supported Parameters. Issue fixed!
looking for a histogram for a 2003 Ecotec Cavalier...not really finding anything and the searches for AFR Error histograms are modifying the Primary VE table, which doesnt seem to be an option on this car?
If no one posts up I can try to make some for you. I'm not at an hpt computer so it will take me a while
Cavalier Histos.Graphs.xml
Cavalier Histograms
you will have to create your own filters to properly filter out coast down data from the main high and low ve tables and of course vise a versa to prevent coast down fuel from having values for non coasting events populate.
std main spark and pe spark tables have filters based on commanded afr so make sure that channel is added.
all ve tables have afr error values so you will have to input your wideband channel to make them work.
make sure you log rpm sae (general), manifold pressure (general), throttle position sensor %, and as mentioned commanded afr.
that should make the histograms work.
I too am having issues with V3. My old config file did not import correctly. I've spent hours redoing everything. The one thing I cannot get working properly is BOOST. I have tried EVERY available sensor and configuration. Just can't get it to show data that makes sense! I have 3 different channels trying to capture valid data.
Right now I am using:
[50030.98]-[50032.98] as a calculation. At idle it is showing -8.3 (or so psi)
I am also trying channel "Boost Pressure" which is generic and also "Boost Low Res". The data I am receiving from these is weird.
Any help or direction would be appreciated. FWIW.....gotta love the knock retard eh!!!????
any chance of us ever getting a few more tables to work with on the LD9 pcms? would love to be able to upgrade my 2 bar gm reflash system which im currently running 22psi of boost with to at least a 3 bar system and maybe get some injector pulsewidth modifiers so my 1200cc ev14 injectors can work properly. @bill
02
chevy
trailblazer ls
aem 34-4110 wb eugo
4200 wot tuning and hauling most power possible
1gnds13sx22289xxx
pcm12576463
Anyone care to share any filters that are helpful while tuning an LNF? Do people disable DFCO for tuning the MAF correction on the low load areas? Haven't heard of anyone using filters on these and on the e38 seems like you can only get useable data by using filters...
does anyone have a layout for the new beta? i have a cobalt ss lnf imy old one didnt import and now lost.
Does anyone have a full layout for Chevy Camaro ZL1 automatic? I'd love to have it. because, my scanner dashboard is a bit bad.
