Results 1 to 20 of 22
Thread: VCM Scanner Beta - CAN Outputs feature?
    Oct 2023
    5
    Has anyone tried the CAN Outputs feature in the beta of VCM Scanner? I've tried to map some PID's to CAN messages without any success, and have also tried outputting static values. I don't see the device transmitting anything over the CANbus high/low wires of the Prolink+ unit connected to my MPVI3, either with CAN sniffing tools nor with an oscilloscope.
    I know that this is a beta feature but has anyone had any luck with it yet?
    I am hoping that, once released, it will be able to repeat OBD-II PID's over CAN any time the MPVI3 is connected - allowing me to display values that are only available via J1850 VPW on CANbus-only devices like the AEM CD-5.
    Sep 2002
    Chicago, IL
    6,411
    It's still a work in progress. We have a couple customers testing and helping development, but the feature is still changing often.
    Hopefully in the near future we'll refine the UI and the back end, and solidify the process enough to whip up some customer facing documentation so that you and others can more easily use it as well.
    We got this guy Not Sure, ...
    Oct 2023
    5
    Quote Originally Posted by Keith@HPTuners View Post
    Sounds good; I am happy to help test if you'd like as I have quite a bit of experience with CANbus.
    One feature that would be *amazing* would be for the CAN Outputs to always be broadcasting the data from the PID's, even when the computer wasn't connected. That way, you could just set your CAN Outputs via the VCM Scanner program, then unhook the laptop but leave the MPVI3 and Prolink+ connected to OBD-II and CAN - and have your data rebroadcasted from the OBD-II PID's to your CANbus without requiring any other unit to be connected.
    In my use case, I have a GM Racing P12 ECU in a vehicle that came with no other ECU's (no BCM, etc) so the ECU only outputs limited data over CANbus since nothing else is "listening" to it. I need to be able to access some items which are only available over OBD-II PID's (such as IAT2 and other supercharger sensor outputs) to be displayed on an AEM CD-5 which I've already got set to read the limited information transmitted over the CANbus from the ECU. Being able to just keep my MPVI3 and Prolink+ connected at all times with constant PID-to-CAN would solve this problem in a very tidy way for me.
    Thanks again for a great product and look forward to more new features. Feel free to ping me if you need additional testing from someone with CANbus experience.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,877
    Quote Originally Posted by iota View Post
    The output works, but you have to intercept the Prolink+ or omit it. I built my own wiring harness to do this, and I have my MPVI3 set up to transmit rpm to my Mainline Prohub so I can avoid an inductive pickup. As long as HPT can scan RPM from whatever's on the dyno, I have my reference.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Oct 2023
    5
    I've got the CAN high line connected to orange lead on the Prolink+ and CAN low on the yellow lead but I don't get anything on those lines, even with an oscilloscope and even with a static value being output. Maybe I need to update to a more recent beta or something
    Mar 2008
    St. Louis, MO
    4,877
    Like I said... you have to intercept the Prolink+. The current setup isn't for the CAN bus on the Prolink+ itself but rather the MPVI3's M8 connector.
    Oct 2023
    5
    ahh, that makes sense - is there a pinout for the M8 somewhere? i've not messed with it yet; wonder if I could just crack the prolink+'s little body open...
    Oct 2023
    5
    I see it, once you start logging, the bottom 2 pins on M8 start a high speed pulse, thanks
    I'm having a similar issue. I have a MPVI2 with the pro link and i have a CAN interface from my Mustang Dyno. i setup the CAN output in HP Tuners VCM scanner and set the data to Engine rpm but in my Mustang Dyno software when the CAN is connected i only see 1 RPM instead of 650 at idle. It appears to be sending out data cause i see RPM its just not accurate. I dont have any offsets define in the CAN Output on the VCM scanner software so im not sure why the data not matching.
    I got Engine RPM and speed working from the HP tuners CAN output but I found a issue in HP tuners if I try to pull MAP or lamda into my dyno
    HP tuners is only sending whole numbers for example vcm scanner shows 4.7psi but the data I?m getting from HP tuners over the can output only shows 4
    Dec 2006
    Pensacola, FL
    510
    DSTECK - I have a AEM 30-0310 and I am trying to log/display AFR on my scanner using the MPVI3 with the ProLink+. I have connected the AEMNet CAN high wire (black/white) to the ProLink CAN high wire (orange) and the AEMnet CAN low wire (green/white) to the ProLink CAN low wire (yellow). I repolled the scanner, added the AEM X series UEGO WB EQ ratio 1 PID. However, when I start scanning, nothing populates in the scanner. Thoughts? TIA.
    I'm not sure if this matters, but my swap is an 84 C10 - 2017 GEN V L86/8L90 with a E92/T87 using a Speartech wiring harness an running a 2015 Corvette OS.
    Sep 2002
    Chicago, IL
    6,411
    For clarification, this is something we're developing and hope to release in 2025.
    The current solutions are simply proof of concepts and will be replaced by our production solution when it's available. No ETA yet.
    We anticipate being able to send and receive data from dyno computers with ease over CAN.
    Aug 2010
    30
    I dont see this options in Channel Config Advance is there a certain version I need?
    Banned
    Jan 2022
    fountain valley
    2,379
    hope to
    Aug 2010
    30
    Keith
    How can I get that feature on my beta to play with it?
    I been doing can bus for 10 years now and want to mess around with it.
    Mar 2009
    Andover, MN
    825
    Didn't know if I should also bump this thread or start a new. Any ETA? Otherwise, I know I tried a couple times with support to create me a CAN channel, with the help of literally the Senior Software Engineer from the manufacture that I am trying to interface into the prolink.
    Aug 2010
    30
    How can I get a Beta to play around with the concept version?
    Oct 2022
    46
    HP home page/ Downloads. you'll notice two choices of the VCM Suite. "latest stable version" & "beta".
    Aug 2010
    30
    Quote Originally Posted by DaveNY View Post
    Im looking for Channel Config Advance Properties to play with Can Bus outputs in VCM scanner
    Aug 2010
    30
