Results 1 to 8 of 8
Thread: '23 Hellcat Cat Warmup/CSER
    Oct 2021
    35
    Does anybody know what tables need to be changed to eliminate the cold start cat warmup mode (negative timing and awful exhaust noise)? This car has longtubes and a full exhaust with no cats and it shreds ear drums on cold start. Tried adjusting the Start and Start Flare tables in the spark tab but no change.
    FODEY_ORIGINAL.hpt
    Aug 2021
    Indianapolis Area
    456
    Try:
    Engine -> Fuel -> Temperature Control -> Cat Protection
    Engine -> Spark -> Advance -> Minimum spark -> base
    If you need remote support, email me.
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Oct 2021
    35
    I fixed it. There were also torque tables for cat warmup that I zero'd out
    Feb 2016
    441
    Quote Originally Posted by Mucho_Boosto View Post
    This
    Nov 2019
    316
    ECM 37855 and 37856?
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    421
    Related to this topic ... anyone know if 34250 and 34260 are threshold values for COT and EOT enrichment enablement, or are these target values for desired cat and exhaust normal operating temperatures, thus if the real-time calculated temp is below these values, the PCM is doing things to try and raise the temps to hit the value stored in these tables?
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    Banned
    Jan 2022
    fountain valley
    2,379
    dont forget 34252
    i have a trick for all 3 of those tables
    the solution is in modifying the axis... not the values of any of those tables cells
    Jul 2019
    Ft Pierce Florida
    35
    Best tip of 2025. It sure cleaned up my tune.
    Thank You.
