Hi, I have a LFX from a 2013 Camaro swapped into a Miata, E39a ECU from a 2012 Impala. When I hit rev limiter the throttle cuts out completely for over a second and doesn't bounce at all. The last issue I had was the car going completely into limp mode when I hit the extreme limited, I changed my rev limits for each gear and it's not going into limp mode, but the complete throttle cut is killing my lap times. Will post tune shortly, any help or advice would be much appreciated. All I could find was updates to the torque delta tables, but it was all for LS engines and not sure how well that translates?
