Results 1 to 15 of 15
Thread: Scatpack hellcat blower
    Tuner Alex14SS's Avatar
    Aug 2021
    Florida
    176
    Question Scatpack hellcat blower
    I am currently testing a setup using the stock supercharger from a Hellcat. However, I am encountering lean conditions at wide-open throttle (WOT). The configuration includes Hellcat injectors, a Hellcat throttle body, and an MMX Hellcat Supercharger Bypass Valve Controller. I would appreciate any insights or recommendations regarding this issue! thanks
    Buy tunes here! GM DODGE FORD > https://tunedbyroleari.sell.app/
    Follow me on Instagram > https://www.instagram.com/alexchutini/
    Mar 2021
    Pompano Beach FL
    473
    why is it stuck in open loop? what fuel pump are you using? why are you missing so many Pids and your map sensor data is wrong ? why is ANN turned off? if this is stock 392 you are going to eat a piston with that tune file
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Banned
    Jan 2022
    fountain valley
    2,379
    before it needs a tune - it needs a fuel system!
    there are a few restrictions that need to be dealt with or its gonna lean out
    what pump did you put in it?
    god damn! i just looked at the log. WOT ; 6000 rpm ; 20 deg lead ; 1.35 lambda ; and a whoppin .7 p ratio
    you have multiple issues
    Nov 2019
    316
    And a Baro of 140kPA!
    Im surprised it didnt turn them slugs into liquid aluminum
    Aug 2021
    Florida
    176
    Quote Originally Posted by N2speed View Post
    tuned off NN for VE tuning. O2 sensors had spacer in it so I?m using WB. Stock fuel pump 392. Hellcat injectors. MAP reads 103kpa on engine off and that?s in FL
    Banned
    Jan 2022
    fountain valley
    2,379
    email me, i have a fuel pump for you
    and suggestions how to remove a couple really bad restrictions that are currently present
    can help you tune it later too but first you need a fuel system
    and prolly some larger injectors
    i have some 1300's here (new) but all you really need is 1050's
    stock demon bare min
    Mar 2021
    Pompano Beach FL
    473
    Quote Originally Posted by Alex14SS View Post
    Why would you have spacers on the front 02s? you need to tune with the narrows bands on open, you are really making this way to complicated and doing it the hard way. with this setup with proper tuning you could actually keep ANN on. You will need a larger fuel pump like a Walbro 450 or a BAP on the 392 pump though. MAP should read right at 100 in Florida your MAP scaling is a little off.
    www.n2speed.com
    [email protected]
    Banned
    Jan 2022
    fountain valley
    2,379
    huh?
    i am sure he is talking about the rear o2's
    but you cannot run a stock 392 pump
    just like you wont be able to run a stock hellcat injector at 58 psi
    if it makes any power...
    it needs to be leaked down,
    Mar 2021
    Pompano Beach FL
    473
    huh?
    sorry typo, I was trying to say use the narrow bands for part throttle tuning, that log he posted was in open loop. you can run Hellcat injectors up to 7PSI with a upgraded pump, but no more then that it will be about 80% Duty cycle with a 11.2-11.5 AFR at 6400 RPMs on a 6.4L
    www.n2speed.com
    [email protected]
    Banned
    Jan 2022
    fountain valley
    2,379
    don't see how you make a blanket statement like that without knowing what mods were done to the fuel lines or what pump gets put in it?
    you don't even know what the stoich of his fuel is and you are calling out AFR's
    Banned
    Mar 2025
    49
    N2Speed is a tuner, not a consultant LilSick
    I am a mechanic guy... do not know much about tuning. Just bought my MPVI and need remote tune support.
    The vehicle I am working on now is stalling after injectors swap.
    Any help is appreciated!
    Banned
    Mar 2025
    49
    Be careful not to get scammed. And, don’t ever pay via PayPal Friends & Family.
    Mar 2021
    Pompano Beach FL
    473
    Quote Originally Posted by Michael_T_HellCat View Post
    it would be best to start your own tread and post up a data log and tune file so we can try to help you.
    Or you can e-mail me the info and I will take a look when time allows.
    www.n2speed.com
    [email protected]
    Aug 2021
    Florida
    176
    so I’ll go ahead and upgrade the fuel system then and go from there. Other than that it fires up a lil funky (every 2nd turn) but I’m trying my best here on what I got to work with. I’ll use the NN and see if I get better results.
