Results 1 to 12 of 12
Thread: 2014 Silverado tuned or trash?
    Advanced Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    252
    My friend has been driving this silverado around for about a year. He put some larger tires on it recently and started to experience a hard 2-3 shift and from what he remembers it didn't start doing that until after he had someone recalibrate the speedo. I can tell the misfire diagnostics have been tuned out which shouldn't have been done and dod disabled. Anyone have a stock 2014 5.3 silverado tune to compare to?
    Sep 2021
    Kentucky
    1,846
    Looks like upshift TM is disabled. There is a lot of rough work in here including the spark table. Stock would probably have more power and much better trans life.
    Sep 2021
    Lexington KY
    329
    Im surprised his transmission lasted as long as it did.
    Sep 2021
    Kentucky
    1,846
    Yep.
    Tuner Balakayt.'s Avatar
    Jul 2024
    DFW, Texas
    66
    Here is a stock 2014 Silverado crew cab z71 5.3
    2014 SILVERADO STOCK TUNE - Copy - Copy (2).hpt
    North Carolina
    4,846
    After you turn TM back on it's going to shift real funny unless you clear all the shift adapts.
    North Carolina
    4,846
    just a heads up.
    Sep 2021
    Kentucky
    1,846
    Some people still believe a tire barking shift through a stock 6l80e means good tuning. Just because its cool dont mean its healthy. Now when you are putting down enough power to break traction on a shift with tm on you are getting somewhere.
    Aug 2023
    Corpus Christi, TX
    252
    I can only imagine what this does to hard parts Thank all of you for the info. Hopefully I will get the opportunity to fix it by returning most of it back to stock!
    Aug 2023
    Corpus Christi, TX
    252
    just a heads up.
    I assume you are referring to the Controls and special functions> Transmission > Automatic> Trans reset/preset function or also the Trans fast adapt/relearn?
    Sep 2021
    Kentucky
    1,846
    I normally only do the reset/preset. Not sure what the fast adapt/learn is for but i have never seen anyone recommend it.
    Dec 2019
    MS
    1,246
    Screw the shift timing up bad enough and it will break intermediate shaft.
