Thread: 2008 6L80e high power 2-3 WOt shift
    2008 Denali AWD
    388 / 88mm E85 1000whp+/-
    6L80e with best parts
    Can't make 2-3 shift at wot. All other gears are fine. I can't get shift to start early enough. No matter what I do the shift doesn't start till 5500rpm but I need it to start the shift at 5000 to happen by 6500. It seems like a hard wot limiter for lowest rpm.
    1. Has anyone experienced this with 08s and solved it
    2. Can I put 2010 valve body/TCM in or the PCM will freak out?
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,114
    Have you considered posting a tune and log so that people can help?
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    North Carolina
    4,836
    Quote Originally Posted by MoBoost View Post
    2008 Denali AWD
    Shift MPH and RPM must be met to shift. Check part throttle tables to make sure the 100% column matches your WOT stuff. You must lead the shift by a few hundred RPM.
    Tune and log attached
