Results 1 to 11 of 11
Thread: 2017 RAM 1500 5.7L - NO idle after BTR Norris CAM install
    Hello,
    Need some help here!
    After installing BTR Truck Norris CAM on my 2017 RAM 1500 5.7L, truck no longer idles.
    MDS and muffler delete - other than that, stock!
    Any help is highly appreciated!
    Attached tune and log.
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    256
    So it just starts and then dies?
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 13.1/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.65" Valves
    Custom Cam 220/238 .611/.589 108.5 LSA 108.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
    That is correct...
    Mar 2021
    Pompano Beach FL
    478
    do you have any data log or any codes?
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Quote Originally Posted by N2speed View Post
    10-17-24.log of ver3.hpl
    Codes:
    - P1DD2
    - P1DF3
    Any help is highly apprecited!
    Tuner MadhousePerformance's Avatar
    Dec 2018
    Florida
    65
    Let me know if this helps.
    Quote Originally Posted by MadhousePerformance View Post
    Thank you!
    I will give it a try!
    Keep you in the loop!
    Apr 2025
    4
    i have done the sam btr setup on mine and it will crank but no start. need help badly
    Banned
    Jan 2022
    fountain valley
    2,379
    shoot me a email
    Aug 2021
    Indianapolis Area
    459
    Quote Originally Posted by Millercustomgg View Post
    Share the current tune and a log over here
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Mar 2021
    Pompano Beach FL
    478
    it doesn't take much to get a Gen3 to fire up and at least idle, tune wise. If it is not firing up then most likely a mechanical issue.
    www.n2speed.com
    [email protected]
