Results 1 to 11 of 11
Thread: L83 with L86 camshaft LTFTs
    Oct 2024
    10
    Hi everyone. I helped a friend with his DOD delete on his 2017 silverado with a 5.3 L83. He insisted on installing the L86 camshaft to get a small bump in performance. Once the truck was back together I disabled DOD and the truck fired right up not issues. One thing I noticed when checking over everything in the VCM scanner were the extreme negative LTFTs. They are dipping into the 30s. The truck idles great and I did not see any vacuum leaks. Any help or insight is much appreciated. I will include the tune and the datalog.
    North Carolina
    4,859
    Can you attach the stock file so I don't have to dig for one?
    Timing is negative throughout. Something seems up.
    Oct 2024
    10
    The entire log is just idling.
    Jul 2022
    Texas
    110
    He's trying to help you. He's asking for your stock PCM tune file so he can compare it to your modified file.
    Oct 2024
    10
    Quote Originally Posted by 96GS007 View Post
    Yes sorry. The tune file is the stock one with just DOD turned off. Nothing else changed
    North Carolina
    4,859
    I take nothing for granted now days. Post the stock file.
    Oct 2024
    10
    Matt 2017 Step 1 DOD Disabled.hpt
    An L86 cam is still AFM. Did he install an AFM L86 cam with LS7 lifters on all 16 lobes?
    Jul 2024
    Quote Originally Posted by MeanMike View Post
    This. A factory L86/LT1 camshaft is an AFM camshaft. I think the only GM GenV factory camshafts that are NOT AFM are the LT5 (no, it isn't just an L86/LT1 camshaft without AFM) and the L8T camshaft.
    Oct 2024
    10
    Sorry. This is the camshaft that was installed.
    https://sdparts.com/i-24504579-sdpc-...q=l86+camshaft
    Aug 2019
    Florida
    104
    Quote Originally Posted by RJINATOR View Post
    Hi, I have a future customer that will be installing this same dod with L86 Non dod cam in its L83 Powered tahoe. Did you find out what was wrong on the trims?
