Hey all,
I am trying to flash my 2004 Viper for my paxton build (working with Havik on tuning. I reached out to them but not sure when I will hear back). I did some research and looked like on some early GMs there was an issue and it could brick the ecu during writing.
I disconnected my aftermarket radio, pulled the fuse for the amp and still get the same error. After acknowledging the messages it has me cycle ignition and then it looks like it is starting to work but then shows failed. I have attached a couple photos.
I even plugged in the factory headunit and tried it again and get the exact same errors. Come up trying to read or write (although I am able to read after cycling ignition).
Any ideas or is there a way to disable the aftermarket radio warnings?
Should add im using the latest version of VCM editor and an MPVI3 which did all updates on last night.
Thank you
