Is it possible to leverage a User Math Parameter as a Functional Parameter in a Graph's Filter setup?
I've set up two Math Parameters to track WOT and DFCO on my GPEC2A Hemi, and would love to use these in various Graphs to filter the data; but it seems you're not able to select Math Parameters as a parameter for the filter function.
Am I missing something here, or is this not an option? Seems like it should be for boolean math parameters ... I do see you can select Scalers, States and Flags ... it would be great if we could define a boolean resulting user math parameter as a Flag, and then be able to use it to filter graph data.
