Results 1 to 8 of 8
Thread: nag1 slipping
    Sep 2022
    14
    nag1 slipping
    Hi everyone
    i have an 07 charger srt8, the transmission is shuddering in 1st gear then goes thru 2 and 3 perfect then tries for 4 and nothing happens and sticks in 3rd pulled trans found K3 clutches smoked rebuilt trans myself and had same issue took trans to trans shop to be rebuilt put back in car and doing the same thing..i rang out all wires from tcm to trans they are good I was thinking of trying to up the trans pressures to try to hold the k3 clutch better . can anyone guide me in that direction or show me a tune that has shift pressures upped possibly? maybe the tcm is bad but i figured to try this first as getting my tcm rebuilt is $450
    thanks
    mike
    Banned
    Jan 2022
    fountain valley
    2,379
    if the tcm is bad hhp sells one for $650
    it shows up with a pretty wicked tune loaded in it too : )
    that tune will not have been tailor-made for your vehicle tho
    lemme know if you want one that is : )
    Sep 2022
    14
    verifying bad tcm
    thats not a bad price for a new tcm with a tune do you have any suggestions or tips on verifying this one is bad i HATE firing the parts cannon at things
    Aug 2021
    Indianapolis Area
    452
    Share the tune you currently have over here (or send me via email).
    I will take a look at it to you.
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Sep 2022
    14
    07srt orig file 2024.hpt
    here it is thank you for looking at it for me
    Banned
    Jan 2022
    fountain valley
    2,379
    i just checked... they are up to 760 now
    BUT, you would be killing two birds with one purchase (known good controller and known good tune)
    if you just want the tune send me a email
    that would be my first step in troubleshooting it
    Aug 2021
    Indianapolis Area
    452
    Email sent to you ([email protected]).
    DodgeBoy.
    That looks to be a stock engine and trans calibration? It should not be smoking the transmission at stock power levels. Not a tune issue.
    But, this quick cal change should give you much more 3-4 shift application speed, maybe it could help not go into limp mode (stuck in 3rd) on the 3-4 shift.
    07srt orig file 2024 - upped (3-4) shift pressure.hpt
    Does it fail the 3-4 shift at high throttle, or just every throttle position?
    2006 AWD 300C Turbo - 10.6@127mph on 14psi - stock pre-eagle 5.7, stock NAG1
