Sounds like you've got a solid setup with the LML Allison and it’s great to hear the truck is performing well. I’ve seen similar performance improvements in older Duramaxes when people add an LB7 EGR delete kit. Removing the EGR can reduce buildup and improve throttle response, especially when you're pushing higher RPMs or towing heavier loads. If you're seeing good results already, the EGR delete could be a worthwhile addition to prevent future issues with carbon buildup and potentially even improve fuel efficiency.
