Do you guys know if it has to be the HPT, or do the Amazon one's work?
thanks
thanks
2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
2008 F-350 03 5.9
Fumminstuning.com
This can't be just any random adapter. MPVI3 expects CAN L/H and GND/PWR at specific pin positions on the ODB connector. The adapter would have to be designed with MPVI3 in mind.
i doubt the OBD side would be different as it's universal in the automotive world, my question is more of has anyone tired the off brand china ones as they are all made over there
2008 F-350 03 5.9
Fumminstuning.com
Do you have a picture/link?
If it's designed for BRP it should work I would assume.
thank you sir, i think the same but won't give me the VR read for some reason. i will try again
2008 F-350 03 5.9
Fumminstuning.com
one more question for you please, what does a locked ecm do when trying to read?
this is what mine shows
ECM: 7E8, CAN, ECM -EngineControl
VIN: 3JBVDAV40PE001018 - 2023 Can-Am Maverick X3
Calibration IDs: ????????????????
Calibration VNs: 41314D31
2008 F-350 03 5.9
Fumminstuning.com
i talked to an inside tech and has to be the brp cable i was told, live and learn trying to save aa buck haha
2008 F-350 03 5.9
Fumminstuning.com
