Results 1 to 12 of 12
Thread: what changes are needed when increasing stall
    Advanced Tuner biholliday's Avatar
    Nov 2020
    Kingman AZ
    211
    i have a 2014 chevy ss sedan and was looking to swap the converter to a 3000 single. What (if any) will i need to change in the trans tune? Or can i leave it the way it is?91 brandon.hpt thanks for looking
    Sep 2021
    Kentucky
    1,846
    I have made some of the more important changes. Misfire detection was disabled already. The next step will be to lower shift speeds, the bluecat tool should do a good job. Wouldnt recommend lockup at wot in any gear.
    Nov 2020
    Kingman AZ
    211
    Thank you sir. Now all i need is the converter
    Oct 2014
    Moscow, Russia
    320
    All you need is not mapped in HPT, so leave it the way it is...
    1. Converter K-Factor vs Speed Ratio (3 tables)
    2. Converter Torque Ratio vs Speed Ratio (2 tables)
    3. Converter Clutch Pressure (2 tables)
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Sep 2021
    Lexington KY
    329
    Quote Originally Posted by verlon View Post
    Where do you find these? I have a 14 silverado 6L80 Im trying to get sorted out with my 2800 stall FTI converter. Higher load its perfect. but lower speeds, esp with the a/c on....its not as good.
    Oct 2014
    Moscow, Russia
    320
    Quote Originally Posted by Estep40511 View Post
    In the T43 OS.
    Imagine you got access to those parameters, where will you find non-OEM converter characterization data?
    Sep 2021
    Lexington KY
    329
    I just cant get mine to stay locked with the a/c on. It surges up and down. More when at lower speeds.
    Nov 2020
    Kingman AZ
    211
    thank you for that information
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    Try these changes. Your shift times are very low, but I left them alone. Might shift hard.
    Russ Kemp
    Sep 2021
    Lexington KY
    329
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Should I raise them up around .35?
    Dec 2005
    Regina, Sask.
    4,256
    I always lower the stock shift times by a percentage. Lower=firmer shifts. Try lowering shift times by .9 at a time till the shift firmness is how you like them.
    Russ Kemp
    Sep 2021
    Lexington KY
    329
    Russ Kemp
    I finally got a chance to run this tune. I went back and readjusted my times. Shifts better than it ever has! Thank you for the help I appreciate it.
