Results 1 to 5 of 5
Thread: Can you change the VIN and the vehicle description without changing the OS???
    Banned
    Jan 2022
    fountain valley
    2,379
    gen 3 swap - 2018 hemi went into 2003 dakota
    customer wanted the BCM and its functions so he got a 2005 Ram NGC3 5.7 hemi controller
    he built a stoker motor purchasing a crank that came with the early reluctor,
    trying to find out which part number was on the outside and and what OS was on the inside as i am typing this
    he "took the controller to someone who used a snap-on scanner to change the VIN to that of the dakota"
    he sent me a read of the controller and looking at it brings up the question -
    can you change the VIN and the vehicle description without changing the OS??? (using a snap-on "scanner")
    if you look at the pics it would appear this controller has the 4.7's OS back in it:
    Mar 2021
    Pompano Beach FL
    470
    I have a snap on Solis and it will let me change the vin on some PCM but never seen an option to change description, I believe that comes from HP when it decodes the vin.
    Some reason MY FCA Software can does not give a very good description on that OS but I can tell you it is different from the OS assigned to that vin.
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    Banned
    Jan 2022
    fountain valley
    2,379
    great thx
    looks like the truck came with a PCM P/N 56028720A_
    which contained the manual trans 4.7 OS 56028616AI (for a wedge motor)
    now truck has PCM #WhoKnows wired in
    containing gen III 5.7 auto OS 56028873AH within
    and that OS does not include an 'airflow factor offset' table.
    Mar 2021
    Pompano Beach FL
    470
    make sure to update to the latest beta, just had them add some airflow tables maybe it will include that OS as well.
    www.n2speed.com
    [email protected]
    Banned
    Jan 2022
    fountain valley
    2,379
    really!
    which airflow tables did they add to what OS?
