Thread: need some input on the tune - 408ci first base tune
    Question need some input on the tune - 408ci first base tune
    greetings, attached is the start-up/base tune along with a short cruise and 1-2 upshift WOT pull log/scan. i understand the injectors are maxed so my buddy's in process of getting 60lb injectors. here's the rest of the mod list:
    70s chevy vega
    bored and stroked 408ci that was originally a 364 6.0
    stock ls2 intake manifold with massive CAI and cone filter in the fender
    cheap headman's long tune headers
    compression ratio is 11.1:1
    LS1 NA Stage 4 cam from lunati 235/242 with 111 LSA
    PRC heads
    the wideband was installed in the tailpipe and using LM-2 wideband
    TH350 with 3500 stall with 3.73 gears
    i realize the lean at the bottom of 2nd gear based on the LM-2 AFR registering +16. i also understand since the widebands in the tail pipe the reading is reading leaner by +0.5 to 1.0ish?
    trying to figure how much to adjust in the MAF range
    2002 vega 6.0l Pablo 408ci 20250501 23 from 13.hpt
    pablo 408 WOT 6.hpl
    North Carolina
    4,835
    The VE is in pretty rough shape on this. This car would do much better tuned in SD and not using the MAF
    thanks for the response. the VE is indeed rough, its a rough draft and still working out the kinks. the car doesnt stall at idle or in drive. im not very familiar with SD tunes as i have majority tuned with the MAF unfortunately. once the higher injectors go in i'll retune both VE and MAF
    5BA8
    5,453
    That's not a rough draft that's just rough. And wrong. Might not stall but it can't run great.
    Cylinder volume isn't correct.
    Didn't really look at anything else.
    email=[email protected]
