Does anyone know how the VSS calculation is done on the P59 PCM? T56 should be a 17 tooth reluctor as far as I'm aware for everything except the SSR? All the Tune files for P59 cars (04 vette, GTO, CTS-V etc) all show a 40 tooth reluctor. P01 PCM's seem to show 17 tooth like expected.
I have a swap car with a P59, DBW, and T56. My cruise works in 1-5th but will not set in 6th at all. Speedo reads correct in VCM scanner, buttons for cruise all switch to yes in 6th. I tried changing the VSS to 17.000 assuming since my OS was original an auto car it was just setup wrong, but then the cruise doesn't work at all. I have a new calibration i'm going to test on the way home from work that has the VSS and VSS/mile etc hand calculated out, but even those calculations vary between P01 and P59. The P01 camaros show a roughly 800 trans revs/mile where the P59 cars seem to be multiplied by the rear gear ratio putting them in the 2-3000 revs/mile for some reason. The description for calculating tran revs/mile is pretty horrendous so I'm not sure if I'm supposed to be inputting the 800 trans revs/mile or multiplying by my rear end ratio. Also i'm confused why all the factory P59's show 40 tooth VSS reluctors.
5-7-21 e30 stock injector working rom pre 42lb flash.hpt
Here's my current OS with my currently working 1-5th cruise. The cars an fbody LS1 t56, 24.7" (245/40/17) tire and a 3.73 rear gear. Cruise works up to 100mph (highest I've tested) in 5th but will not work at any speed in 6th
