Results 1 to 13 of 13
Thread: MPVI 3 Auto Logging Setup
    How do you guys have your logger set up to start and stop logging. Having a laptop connected to log is not reasonable on a watercraft.
    Tuner JT_alex's Avatar
    Mar 2023
    SPAIN
    59
    Quote Originally Posted by whittlebeast View Post
    on MG1 logging without a laptop connected is imposible, from hptuners they told me this.
    i even can't add channels on mg1,did the patch OS with the editor but the channels you have on the foto in my scanner does not apear
    This figures, the bleeding edge is not for the faint of heart. Now I have to give one of these a ride on the ski.
    Jan 2022
    Galloway NJ
    183
    use a laptop connected to the MPVI3 through Bluetooth. start the ski, start the log, put the laptop in the storage compartment and do your logging. it's really easy!
    Apr 2021
    21
    Why not just use the standalone logging feature? This way the only thing you need is the dongle. I made an extension harness for the diag connector so I can keep the dongle in the dry box at the front of the seat. This makes it very easy to start and stop logging and I don't have to risk my computer getting destroyed.
    Are you getting logs on your MPVI3 device on the 2024 or later ski? I am not and was told it does not work right now but apparently HPT is working on the issue.
    Apr 2021
    21
    I'm on an older ski. I missed the MG1 in your post. That makes a lot more sense now.
    Apr 2015
    3
    Hi, can anyone check hptuner seadoo connector cable pins ? Is it like in the photo ? BRP OBD pin..png I have BRP cable but can't connect to MPVI3.
    Mar 2022
    7
    Any update on when the logging will be working on the MG1 ECUs
    This is a fairly serious issue as we are finding logging to a computer thru a 6 foot usb cable is very unreliable. Windows keeps reporting device not found. We need logging to the MPVI3 to work as advertised.
    Jan 2022
    Galloway NJ
    183
    bluetooth
    Tommy, did you get Bluetooth to work?
    Jan 2022
    Galloway NJ
    183
    that's all I've been using. works great.
