Results 1 to 1 of 1
Thread: Short shift issue after updating Procharger
    Have a 2011 mustang that shifted fine before upgrading the Procharger. We have moved RPM, speed, N/V, turned anticipated shifts on, off. So far it hasn't mattered, it has shifted at 5200-5400 rpm. We applied the RPM patch and it turns 8400 RPM just fine if you put it in 3rd. Any incite would be helpful. I'll post the tune and a log, some things may be a bit wonkey as we've literally been throwing about everything at it and not getting a response. Previously, it shifted above 7,000 perfectly fine. We did not change the trans tune what so ever before this started happening.
