Oh, in that case it might actually be something you don't want to edit. You may have just made the acceptable window smaller and the learned value or something is outside of it now, throwing an error.
I have very little DQ381 experience, but I think you actually want to edit the stuff in Clutch -> Adaptation in order to increase max torque and clamping pressure. You need to set the "point 4" values to higher value and adapt it, you basically set the torque vs clamp pressure.
Ecutek guide knows more than I do:
https://ecutek.atlassian.net/wiki/sp...mission+tuning
