I gave up on the tune translation service and flashed the stock OS back to the ECU because neither hammer nor droid would write the custom OS. Then used Droid to read/write the modified bin file using a bench harness. I don't think I would try it with the ECU in the car!
Spark now goes above 40 degrees, and the car is actually running a lot better with the stock OS. So, this was a blessing because the custom RTT OS was not acting right anyway, and I now have access to many parameters that HPT left out, such as multiple transient fuel tables!
I want to thank you (gametech) for your quickly defining the problem for me!
