I set up my scanner to capture MAF Err using STFT's (default from HPTuner) and another using my WB (used hpt afr err math).
The diff between the 2 is significant in the lower hz range. The WB table keeps wanting me to add, the STFT's say we've had enough... and by the way it drives I believe the STFT's.
Why is that? I understand many folks like the WB just for WOT, but why is it that far off in the cruising ranges, might I have a problem or is there a specific area I should address only with the WB and only with the STFT's?
If it's a problem maybe some air is getting to the WB after the O2's? That feels like it would tell the WB it's leaner than it should be. It's a new exhaust with a Ball/Socket joint and a welded WB bung that are after the O2's, no noticeable leaks.
Last log attached.
short drive V5.1.7.hpl
