Results 1 to 15 of 15
Thread: how can i do the "Backfire" tune?
    Dec 2015
    Jizan, Saudi Arabia
    32
    Question how can i do the "Backfire" tune?
    hi,
    I tried to make 2015 dodge challenger r/t and 2013 dodge charger v6 backfire, but there are three main problems!
    1st. the car does not backfire unless its moving and the gear is in Neutral after pressing and releasing gas pedal.
    2nd. the car does not backfire while its stopped at all !
    3rd. if i release the pedal after a WOT, it goes crazy! the rpm keeps going up and down while deceleration.
    it seems like there is a table preventing the backfire from happening, but i don't know witch on is it
    Note:both cars does not have cats on them!
    Thanks,
    May 2015
    1,908
    besides the obvious question of why you want to do this, you should post up your tune.
    Mar 2015
    Pittsburgh, Pa
    51
    I will admit the Jaguar F-Type R has the sickest exhaust sound out of any car right now and if i could make my car sound like that with a tune i'd do it in a heartbeat. Now if you're talking about that corny ricer backfire then i'm good but if you meant that crackle pop and gurgle someone please let me know as well cause i want to do that!
    Nov 2009
    All Around
    3,149
    DFCO setting with hot exhaust will give you that
    May 2015
    1,908
    Depends on the vehicle, I disabled DFCO and had nothing coming out the tail pipes even catless. I think you will need to disable the DFCO but also have the VE table very high in the decal area so it dumps fuel.
    Dec 2015
    Jizan, Saudi Arabia
    32
    Quote Originally Posted by 06300CSRT8 View Post
    Quote Originally Posted by SultanHassanMasTuning View Post
    I did the DFCO, that is not enough for it to backfire, i did manipulate with the partial timing to make it backfire, but when i left my foot of the gas it doesn't backfire like if there is a table that demands more power.
    I will post my tune with a data log tomorrow.
    Nov 2009
    All Around
    3,149
    openloop will also help
    Dec 2015
    Jizan, Saudi Arabia
    32
    this is my tune, and a datalog of what is happening along two pictures to show where the problem is happening!
    This is the problem; while the gear is on Drive rolling on low load and high RPM, IT DOES NOT backfire, like if there is a table that demands more power.
    And this is the backfire happens only on Neutral gear with only one problem! the car must be rolling to backfire!
    and why i am doing this?
    Well, a lot of guys on this part of the world does it just for fun, at the end of a race, you backfire to celebrate .
    Nov 2009
    All Around
    3,149
    thats way too aggressive with negative timing
    Dec 2015
    Jizan, Saudi Arabia
    32
    I am thinking around -30 degrees would do be just fine, and i don't think that its too aggressive, i've tried -45 and it's sound changed from a pistol to a shotgun! That was too agressive and you could hear the engine screaming!
    Any suggestions?
    Dec 2014
    Palmetto, FL
    880
    You can go into your min spark tables and make all the values a negative number to give you that popping that you might be looking for.
    But there is no reason to put negative numbers in your WOT spark table like you have.
    I would put your spark tables(PT and WOT) back to the way they were before putting all of those huge negative numbers in there. And just try adjusting min spark table only, and see how that works.
    Apr 2025
    5
    help do some pop and bang or crackle clean way
    Some Body can help me to do pop and bang Dodge hemi SRT8 V8 6.4L
    Stock exhaust nododge charger hemi
    and if you can add some crackle
    Clean way please
    I would appreciate it
    Tuner MadhousePerformance's Avatar
    Dec 2018
    Florida
    64
    try this
    pm me if you want more help
    May 2018
    Germany
    623
    Spark Table changes, if the car is rolling.
    There’s a trigger to activate idle mode for stop conditions.
    Dec 2019
    45
    I disabled DFCO and added negative values in Min Spark and other spark tables in the decel areas. I thought it was going to blow my mufflers off!!! I am catless with Kooks headers. I came back home and went back to my old tune. That burble tune is not for me... lol
