Results 1 to 6 of 6
Thread: Channels disappear after starting scan
    Jul 2023
    6
    Hi, I'm new to HP Tuners and curious if anyone had an issue with scanner having channels disappear? I have a channel config file from my tuner provided which I load into the scanner. I connect to vehicle and once I click on start scan, most of the channels listed disappear. My vehicle is a 2012 Ram. I'm using the MPVI3 and a AEM 30-0334 A/F Gauge. Thanks!
    Banned
    Jan 2022
    fountain valley
    2,379
    Shoot me a email if you would like
    I will connect with you and show you how to use the scanner
    Advanced Tuner Stoopalini's Avatar
    Nov 2023
    Central Texas
    421
    Some of the channels disappear because your tuner sent you a default channel list he uses across multiple vehicles. The ones which disappear are most likely not the right channels for your vehicle ad thus not supported.
    You could try doing a "repoll for supported parameters" under the VEHICLE menu after connecting but before scanning. You shouldn't have to do this every time though.
    If you're still missing key channels, ask your tuner to send you a correct channel list.
    2023 Dodge Durango R/T (5.7L) with Tow & Go Package (build thread)
    Gen 5x Whipple 3.0L Supercharger
    Smooth Boost Electronic Boost Controller
    SRT 392 Air Intake Conversion
    92mm Hellcat Throttle Body
    Mighty Mouse Mild SRT Catch Can Setup
    Jul 2023
    6
    Ok will do. Just wanted to make sure I was not doing something wrong. He's a reputable tuner in some groups I'm in, so was hoping he would know what to send me the first go around.
    Banned
    Jan 2022
    fountain valley
    2,379
    he sent you a list that with A BUNCH of channels that are not used when logging any year mopar
    Aug 2021
    Indianapolis Area
    455
    Another possibility is to add them manually
    DodgeBoy.
    Email / Remote Tune: [email protected]
