Thread: NYS inspection vs tunes
    Potential Tuner ranger-rick's Avatar
    May 2025
    6
    has anyone had any issues with using a tune vs the NYS inspection?
    i am new to tuning and considering tuning my 2016 challenger. i am assuming as long as the tune doesn't through any CELs (ex messing with O2 sensors) its all good but (again) I am new.
    thank you in advance RR
    Sep 2021
    Kentucky
    1,839
    Make sure all your monitors are running and passing. Not sure to what extent they are inspecting. No cel and all monitors passed should pass a inspection.
    May 2025
    6
    i am reading conflicting reports on custom tune detection vs OE programming. I was hoping some NY tuners would share their experiences. I assume you are correct (ie monitors are running and passing) but NY is always passing some new law that makes things difficult. It also depends on the shop doing the inspection. RR
    Aug 2017
    Quakertown PA
    549
    Call https://www.hemitunerperformance.com/ there in NYC They'll have an answer for you , all the stuff I've done for NY has been ok, as long as the Monitors where fine the tune was fine.
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
