Results 1 to 12 of 12
Thread: New Hellcat Crate Won?t Start
    May 2025
    6
    I’m new to HPT. I have a new hellcat crate with stock harness/ecu that I can’t get started. Fuel pressure is good 60. I’ve checked all fuses and sensor connections. I did the pedal learn function with HPT. Manual says to do crank/cam relearn, but when I attempt that in HPT it says engine must be running.
    There are a couple codes. I know U1110 is just because the CAN bus is not programmed yet. I’ve attached the screen shot. I’d appreciate it if anyone has seen this issue or has any ideas
    Spark advance showing -64 seems odd but maybe not accurate since it isn’t running?
    Banned
    Jan 2022
    fountain valley
    2,379
    hey eric hi
    i can help ya
    shoot me a email and we can connect
    don
    Aug 2021
    Indianapolis Area
    453
    What tune are you using?
    Did you change anything?
    DodgeBoy.
    Email / Remote Tune: [email protected]
    May 2025
    6
    Using the factory hellcrate harness. No changes other than the pedal relearn. I pulled a couple plugs and confirmed injectors are not firing and there is no spark during start.
    I've attached the file if anyone can take a look to see if anything jumps out. A CAN communication setting? Should all of these be set to 'Disable" since it is a crate swap with manual?
    ThanksStock Tune Original.hpt
    May 2025
    6
    Bumping again to see if anyone is willing to take a look at the files and has an idea. I've reached out to MMX where I bought the crate too.
    I've attached the scan file during crank. Shows barometric pressure of 16 psi, this is a little high, but I'm at sea level so shouldn't be too far off. Is throwing P2227 code.
    Ambient air temp 255*, which is obviously not right. IAT/ECT temps read normal.
    Could either of these prevent start up? I've read about TMAP sensors causing limp mode but not 'no start'
    Mar 2021
    Pompano Beach FL
    472
    What ignition switch are you using?
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    May 2025
    6
    Factory 1972 Dart switch - tied to the hemi harness so using that start relay/circuit
    Mar 2021
    Pompano Beach FL
    472
    Ok what you need to do is make sure power does not drop to the PCM between run and start, if it cuts it will reboot the PCM and cause this issue.
    www.n2speed.com
    [email protected]
    Aug 2017
    Quakertown PA
    550
    Quote Originally Posted by EricT1 View Post
    There's a good chance that's your issue, How old is the switch ? I helped a local guy two years ago with a 69 notch back Cuda and Hellkitty crate set up , in the end it was the 54 year old ignition that led to some real foul language .
    also , that 64* you see for spark when you hit the key , is normal , they all(Crate PCM, OEM PCM) do it.
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    May 2025
    6
    Good catch, thanks guys! It does look like the voltage reading flickers turning back from key start to on. I'll bypass the switch after work and try it. Fingers crossed
    May 2025
    6
    Success!! It was the ignition switch. Fired right up after bypassing. I really appreciate it guys. That would have been the last thing I would have thought about. Had me stressing. Thanks again
    Mar 2021
    Pompano Beach FL
    472
    glad it worked and thanks for the update.
    www.n2speed.com
    [email protected]
