LML Xdf file help
Hello Everyone, I have been working on some parameters that I noticed that Efilive has access to in their editor, so I figured I'd transpose them into VCM Editor. I listed these parameters below with an example .hpt file, use them if you want. I'm looking for any info on how to make parameters 4-digit decimals on the VCM editor side, it seems to work on tunerpro, I'm also looking for someone to help me out with my Main Injection Factor Based On Mode & Stage tables, it seems like the High and low funtion is not translating to the vcm editor, the max is 4 and the minium is -4 but it will not let me go imput 4. I tried to upload the .bin example file, but it is not letting me. Sorry, new to this forum, not sure how everything works yet.
Holy balls! Are you trying to get yourself banned?
https://forum.hptuners.com/showthrea...pliance-policy
I'd suggest taking those files down before the mods see them.
I'll take a look at what you're asking, but best take it to a PM.
Edit:
Your value is a signed 16 bit, with a factor of 0.0001220703
The actual range is -4 to 3.9999.
In VCM Editor, the decimal range is controlled by the Editor, not the XDF. Use the decimal set buttons to adjust as required,
