Results 1 to 8 of 8
Thread: interface was found but no vehicle power was detected error
    Jun 2023
    14
    Went to log the other day and keep getting this error. Checked all fuses, checked power to the OBD2 port and it has 12v so I?m at a loss. Any thoughts? Thanks
    Nov 2024
    36
    Resync interface. If that doesn't work re-connect and disconnect several times until it loads. Also plug and unplug your USB to the MVPI.
    Jun 2023
    14
    Quote Originally Posted by BuildDontBuy View Post
    Ooooo I didn?t even think of that, done and had a firmware update so I?ll give it a go when the laptop is a bit charged. Thanks.
    Jun 2023
    14
    Just tested same error.
    2,787
    Try reading a different vehicle.
    Oct 2014
    Moscow, Russia
    320
    Which interface are you using?
    MPVI1 had a power input mux TPS2113APW which burned when cranking with not so healthy battery and gave the same error message.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Jun 2023
    14
    MpvI3
    Jun 2023
    14
    Went to auto zone and their scanner powered on when connected to the OBD2. So I’m guessing my plug is borked.
