Originally Posted by
rebuildman
2007 5.3 Silverado with original PCM and tune which I licensed. It is a DBW system. I added a turbo so I needed the 2 bar OS. I downloaded a 2004 file from the repository here. It had the 2 bar and RTT OS. After loading it in my throttle quit working. Did a compare on the original tune and found some throttle settings different, so I changed those, still no help. I switched back to the original tune and throttle back to working. So the question is is there a tune I can use that will allow 2 bar and my DBW to work? I see another tune in the repository from a 2006 5.3L, it does not show any throttle differences when doing a compare of the two tune files which leads me to believe that it is a much closer match? Before I buy credits to load this can anybody say if it does work on a 2007? Thanks!
